What should be the rpm of GLI 2014 (current shape) 96k driven at 125-130 on motorway Mine is going to 4. Mechanic says ke clutch Ka masla hai.
It's okay. Do not mess with its engine. Only if you feel car is struggling while climbing inclines then think about changing its clutch plates.
1.3 gli does 120km/h @ 4k rpm.... Its normal dost
Thx
Gli at 120km/hr will have rpm around 3100, I have gli A/T 2017 and its rpm usually at 3k when I am at 120, 4k rpm are around 145-150 km/hr when eco light also disappears.Check clutch as its sign of weak clutch plate
AT cars have different final gear ratios than the manual cars....the poster here i believe has a manual gli and the rpms he is getting are correct .... while ur auto gli rpms are also correct..
Oh really !! then my bad I thought its AT
