That is always due to wiring for the abs overextending and snapping.
Its because the wiring only has enough flex to accomodate for wheel movement of original stock height. Raising the body up also can be seen as pushing the suspension further downward.
The wiring installed cannot accommodate that. You can try to remake the sensor pigtails about 6 inches longer (they are shielded wires though so plain extending wont work)
