City comes stock as 55/60 Watts bulb. If you fit in 90/100 Watts bulb, you will need a relay as well. If you are ok with unnecessary cuts and all in your car wirings, honestly any 90/100 W bulb would do. If you want to stick with stock wattage, go for a good brand of H4s. I have tried Osram, Phillips, AAA.... They all are very good but yes their life is generally shorter than stock bulbs. If you can afford, go for retro bixenon projectors. They have the best output with laser sharp cut off
