When I start engine of Pak Suzuki Wagon r, its handbrake indicator remains on and while driving when I increase pressure on acceleretaor it goes off but whenever I decrease pressure on accelerator the handbrake indicator again goes on.Can anybody tell me why is it so?and should I check brakes or is it electrical problem? Thanks.
check the brake fluid that might be less the the required amount
Its near low level but within required range
refill it and check if the issue still persists if it does get it checked by a mechanic
Electronic connection khrab ho sakta hay
Check your brake fluid. If its low then look at the cap of the Brake oils bottle, which oil it needs. Then full it to the required maximum point.
This is the sign of worn out brake pads, you need to replace the brake pads, dont fill the brake fluid, once you change the pads, brake fluid will come back at max level.
If it’s the oil level issue then it shouldn’t go off. It can be an electrical issue. Check the manual if the brake service indication is via this light as well I highly doubt it in Suzuki but how knows.
top up the brake fluid issue will be solved.
Electronic problems hay Bhai man lo mary bat
Why aren't you going to any good Suzuki 3S? There could be a possible electrical fault under the handbrake, most probably.Or, there could also be a brake fluid issue!
