Last Friday, I went to the workshop for servicing and got my manual transmission fluid drained and re-filled with Warco Gear Oil SAE 90 since the transmission oil was now 6 years old although very low mileage on it.
After the transmission oil change there is difficultly when I try to engage 1st gear.
Sometimes have to force it in or re-clutch and re-engage.
Surprisingly, 2nd, 3rd, 4th & 5th gears are quite smooth.
When the car is stationary there seems to be no problem while engaging 1st gear or any other gear. Now when the car is moving I cant engage 1st gear and have to do it by force. If the car comes to a complete stop I can engage the 1st gear very smoothly as if nothing is wrong.
Do you know what is the problem ? Anything wrong with gearbox, clutch or the manual transmission fluid ?
The second question is: Is there any problem at all ? I mean is it natural that 1st and reverse are not easily engaged when the car is moving ?
There was no problem before I changed the gear oil. The car in question here is Chevrolet Exclusive.
Help please
