The #1 cause of automatic transmission failures is overheated transmission fluid. Today's cars generate extremely high under-the-hood temperatures. Add to that the heat generated by an automatic transmission, and you'll see why adding an auxiliary transmission oil cooler is a must for guarding against costly transmission repair.
Automatic transmission fluid cools, lubricates and cleans transmission components. A transmission cooler is basically an auxiliary radiator that provides extra cooling for automatic transmission fluid. When transmission temperatures exceed 200? F, transmission fluid is strained to its limit. Overheated fluid won't properly protect transmission seals and moving parts. When oil temperatures exceed 200? F, oil breaks down, causing seals to crack and leaks to occur.
Installing a HAYDEN transmission oil cooler will help prevent transmission burnout. It's a small investment now that can save you on repair bills later. With each 20 degree drop in operating temperature, your oil and equipment life doubles. By reducing your transmission oil temperature as much as 60 degrees, a HAYDEN transmission oil cooler can greatly extend the life of your transmission.
MADE IN AUSTRALIA
