Brother Stanley Headlights pair is most expensive will cost you 7,500 Depo ones are as good as OEM and should cost less.
FCC clutch plate made in Japan is OEM and usually works for 100,000 KM or at least 60,000 KM unless you are a drag master.
FCC clutch kit (clutch plate / pressure plate and thrust bearing) will cost you 22,000 from dealership and 12,000 from wholesale market.
Second number is Excedy / Daikin MAde in Japan will cost you 10,000 rupees.
Third number is AISIN /AESCO Malaysia and will cost you 7,500.
Let me know if you cant find them at your place.
