Hi,
I would like to know what are the replacement bulb options for corolla (2013) model. I currently have the stock factory bulbs (Halogen) installed with stock fog lamps. All of them produce the warm light 3200k temperature (which all halogens do).
Now my question is that the low beam headlight dosent have that much visibility even with the fog lamps on (My headlights are clear not faded). Once i open the high beam the visibility is perfect, but i cannot use high beam all the time as it will be annoying for other cars on the road. I was thinking to go with LED in low beams but the issue is that all leds are white, where as the fog lamps and high beam would still produce the warm temperature so it wouldnt look nice. So if i switch to white i'll have to change all the bulbs A to Z to white LED (low beam, high beam. parking and fog lamps), which i dont feel like doing as it would be a hassle and costly. So what should I do?
1. use a higher wattage halogen in low beam, but would it work fine and not melt the headlight ?
2. Just upgrade the low beam to white LEDs and let it be ( A mix of warm and white)
3. Do LEDs come in warm temprature (3200K) ??
Please advice.
