I want to adjust the headlight beams of Mehran. Currently light beam is tilted upwards and towards right. The headlights have 2 adjustment screws at their back. One is at the top center and other one is at the right side. Please guide which screw is meant for which adjustment up/down and right/left and the clockwise/ anticlockwise rotation impact/relation of these screws?
My best guess is that the one on top center is for up/down and the one in the right is for left/right.
I came to the conclusion because of the location of the screws!
Would appreciate if anyone can confirm that
There's a thread just for Mehran users.its called 'Mehran user experience and tricks'. Would've linked you there, but I'm on my phone atm;(
If specifically talking about Right head light If Beam of your headlight is upward than Loose the Screw that is on topFor right and left issue adjust the screws that is on bottom and adjust it as both are tight equally
i have issue of mehran headlight cut off position.. left side head light is way up and cannot be adjusted with up down screws... where as right side head light aim is pretty good... any help??
