Dear PW,please advice, third time my car heated up and i replaced gasket. Cleaned the radiator fan is direct also
What should be the cause?
Sent from my SM-J700H using PW Forums mobile app
No use of coolant, bad Thermostat valve, clogged radiator, clogged water channels inside engine, slow fan, bad water pump, bad radiator cap etc. etc.
Use coolant, thermostat valve removed also...radiator also cleaned.replaced radiator cap with original.suzuki. what should.I.do?
Which car?
Cultus, 2009
What about the condition of.1:- Radiator. 2:- Radiator Fan.3:- Water pump.4:- Metal pipes.
Sent from my D2502 using PW Forums mobile app
Radiator washed 15 days ago..
Fan is direct
Water body havnt.checked.yet
Metal pipes seems.fine..water.body havnt.checked yet..
I meant to ask what about the condition of radiator. Clogged fins or clogged water channels in radiator.?
No..
In which city you are maybe i could help you for a mechanic.!
Islamabad/Rawalpindi
Please replace your radiator with Japanese brand. The problem will be solved. If you want assistance for a genuine one, I can help u in RWP.
Oh sorry mate... Don't know about any in ISB/RWP. Some members from ISB/RWP can help you in this regard.
BTW Your car's radiator might be clogged or T.valve is not working right... Does your car have T.valve if yes then check its operation.? If that is working right.
Thanks Buddy.. T.valve is removed earlier.. how can I check my radiator performance? Is it clogged or not?
Please assist.
A big No to Japanese Aluminum Radiators. Use Alwin or Loads Radiator Copper one's only.
