Cultus 2006, no thermostat valve installed and direct fan. Was recently done with gasket job, head facing and radiator service. However, the car reduces water in small quantities when using without A/C and also doesn't heat up (the needle wont move up) but whenever I use A/C it starts heating up and reducing water as well. After around 40km run the water is almost empty in the radiator. What could be the reason for this issue.
