if the thermostat valve is present in system the Radiator cap shall be checked & replaced 1st. If the vehicle is running on WATER, the water pump aka water body has corroded. The cavitation in system cause such abrupt temp variation over the cluster gauge.
Start from radiator cap. always use coolant.
