Anyone who can guide me related to suspension upgrades for revo . I want to uplift suspension
Cheapest readily available options with Xtreme 4x4 karachi. Ironman kits and 1 other brand.
There are so many out there do you research
I want to install ironman bullbar ... it’s weight is 70kg+ so do i need to upgrade suspension for that ? 2) does installing coils in front suspension for lifting it makes hilux’s stability issues. ?
Without suspension front will be bad so suspension is must. Adding shocks and spring both is best approach. For stability I don’t think 2” will be a problem but if lifted higher yes
Someone told me that installing arb or ironman suspension with 2 inch lift causes the ride more robust/stiff ... making it more uncomfortable . What would you suggest?
Yes he is correct arb and iron man coil springs have more load ratings which would result in harder ride than stock suspension. But if you consider putting bullbar you need to put suspension because extra weigh will make your vehicle soggy at front.
