the Pakistani models do not have that, the pump idle system can easily adjust for 200 rpm drop - If yours is not doing that then you have 2 choices.
1 - add that separate idle up system - you lose about 10% pedal as its pulled in by the idle up
2 - repair the injection pump to perfect, dead on accurate, original spec and install it with perfect dead on accurate timing.
