To open the door lever use a flate screw driver and lift its sides up carefully.Do not use have hand you may dameged the pannel or door lever.When the side ring come out you will see a screw to remove the lever.How ever to remove the pannel you do not need to remove the lever compeletly. Hope it will help.
