liana's capacity is of 4L engine oil. Its confirm.
for xli people use 3.5L & even some people 3.75L also.
Many people only ask to pour 3L oil in the Liana. Because they play trick and change oil early like after 2k. But technically its wrong method. One should feed the exact amount of oil in the engine as it requires infact.
METHOD TO DOUBLE CHECK
buy 4L oil and put 3.5L in liana.
Check the oil level from the dip stick. It will be slightly less than full.
Pour 250ml more and check with the dip stick, it will show full. But yet infact there is space to pour rest 250ml in it.
So pour all 4L, confirm with the dip stick and relax.
By the way which oil you are presently feeding to liana and what is its change interval?
Sent from my GT-P1000 using PW Forums mobile app
