you mean that your engine is not revving briskly and bogs down at acceleration, I would check the engine properly first, timing belt alignment, distributor for jammed up bearing plate and flyweights - improper fuelling. With a slipping clutch your engine should have enough torque to completely destroy the clutch, if not get your engine looked at first
