Hello PW, I have Mehran 2007, i need to change the wiring, fuse-box, lights and speed-o-meter. I need to know few things
What will be total cost if I'm going to get this done from Suzuki center ? Even that would be reliable but obviously will cost more.
What it will cost if getting this done from some good electrician, and from where i can buy these parts, though plaza is best place to buy these i guess; but still i want to know also the exact cost of these parts.
Suggest some good electrician near Clifton, DHA Ph4/5, or adjoin areas? if you prefer to get this done from electrician.
I?m going to replace these largely b/c my car is having some electric issues lately and i want to get rid of these.
Wiring: i want to get the proper wiring done. Wiring looks messy and lots of cuts and solution-tape coating is there.
Lights: want to replace lights as one of head-light is dim, also reverse light is not working along with left side break-light, couple of indicators also not working, so want to change all in one-go.
Speed-o-meter: only speed needle is working properly, all others fuel, temperature, distance counter even indicators like high-beam, and hand-break are not glowing. Showed it to an electrician he opened it and said to replace it. All these indicator stopped working one by one from last 5-6 months.
Fuse-box: i have noticed it gets hot, also have seen that couple of fuse get bent due to heat and later get burnt.
Fan: a fan would not cost more in compassion to above parts i guess
moreover if there is some issue with fan it will also vanish after replacing it.
