1) u set ur gain to full . and then see ur system will max out at volume 10-14
the gain know are rated from higher voltage to lowest voltage
hence full gain means , setting gains sensitivity to lowest voltage
therefore Hu prevolt increases with volume , so
gains set at full ,(5~0.2v)
0.2v selected ,
HU 4v output , at 5v volume , HU makes 0.1 v
at 10volume Hu makes 0.2v ,HENCE GAIN MATCHES = PREVOLTS VOLTAGE
there more max power out from amplifier
now set the gains to the minimum and now see ur system will max out at volume 35-40
gain set at minimum , i.e Highest voltage sensivity
let suppose Gain knob 5 ~ 0.2v range
Gain set to minimum 5v
HU makes
0.1V @ 5 volume
0.2v @ 10volume
1v @ 18 volume
2v @ 25 volume
3v @ 35 volume
4v @ 45 volume
so at 45~50 volume , every thing flat
he having max power @ 40~50 volume
Until and unless it makes 5v(gain setting at minimum) amplifier wont hit its max power
this why No body set gain to minimum , almost half to way full
@ kevin adjust kar hi is liayay rahian to get the power at certain volume , thats why i call it power knob
adjusting sensitivity from current Prevolts (certain volume )
is the work of gain to get power from amp
