Sirs
My 2005 Civic PROSMATEC has a 45AH AGS liquid battery with a CCA of not more then 280A.
The alternator is rated at 90A @ 5,000RPM.
I cannot even handle a single 308 with a proper VTREK mono (speedometer and headlights start to dim at each bass note), even with a 4AWG Fusion Big 3, continuous playback is not possible without starting the engine.
This JBL is very good but its not efficient, no class AB full channel can be more efficient then a class D dedicated mono, even if its from a JBL or a flagship GTI product .
A JL audio HD AMP is efficient, it gives 750W RMS @ 4 ohms, returns a 110 DBa signal and it does that with a 60A fuse.
A mainstream Kenwood X1200 needs just a 30A*3 fuse for 1200W CEA rated.
and an Alpine V2000 can deliver 2000W @ 2 ohms for just 180A.
They are all low noise AMPS, real competition AMps like Kicker Warhouse has a 250A rating and everyone knows what it is capable of.
@geforce<SCRIPT type=text/javascript> vbmenu_register("postmenu_2464604", true); </SCRIPT>
[QUOTE][Continuously , alternator powers is 5~10% is greater then amplifier
s required current i.e look on fuse ratings (no battery involve )
using amp @ full throttle
to handle 200a rated amp , alternator should be like 210 ,220 amp etc /QUOTE]
Sir the best alternator I have seen was in a 100 grands BMW 760LI, rated at 160A, the biggest I have seen in Pakistan is that 110A @enerlevel<SCRIPT type=text/javascript> vbmenu_register("postmenu_2464594", true); </SCRIPT> showed.
The only things left are some serious Optima yellow top batteries and multiple stinger 2 Farad capacitors, possibly a digital or hybird one that can cost a fortune.
Regards
