while my mehran is parked if i turned the steering wheel left or right there is noise from front springs..
Are they original or changed?
If they were changed, the coil probably did not settle in the groove properly. You might need to cut the spring or install rubber pads.
not orignal the coil spring or local install from shock mechanic,
That is what I thought. Either get the original replacement springs our you will have to cut a piece off the top of the spring to make it suit in the groove.
Sent from my X10i using Tapatalk
and what should i do with the rubber pads?
