hi guyzzi have a civic 1987 the shape is of 1984 to 1987i want to swap its engine to a newer mode ie 2000 plus civic oneplz suggest what can be fitted easily and in low costi will use cng on ityour replies are awaitedplz helpiam in karachipeace
any one?????
A D Series Can Be Swapped Inn Easily....!! Wiring + Other Fueling Work Needed As These Are EFI's..!!
You Can Also Get D15B Swapped Inn
sorry bro cant understand these terminologiesplz can u specify like D15B came in which car and how much it would cost??
Its 96-2000 JDM Civic EFi Engine.....!!Cost Around 40-50K Complete With Wiring ECU Tranny...Depending On Market And Seller....!!
Which Engine You Have Got Earlier..Mention The Name
the stock on i-e 1200 cc 1987 model
the first pic is stock engine and the second one is what i fount on the net which i think is the 2002 civic engine swaped
well The On Swapped You Shown Is ZC DOHC From 88-91 CRX......!!
Well D15B Can Be Swapped Inn You Car And Looks Like This
D15 Or D16 From Civic Vti...Both Can Be Swapped Depending On What You Get Since D16 Is Not Usually Available Mostly
will be a nice swap
it will cost you lil high in price and i suggest you that do get change engine and your this engine wil be sale easily and dont cost you much money and your car will be as new i have experienced in my car and working great do change all assemblly i mean change all things specially Distrbutor wiring kits etc etc
where should i get the swap done??? my budgut is 50000. is it enough???
c'mon guyzzz where r u ppl???
HELLLOOOOOOoooOOooOOo
if you need the swap done by the an expert here'sthe number plz contact 03333778530 or 03472297109or any thing plz ask via contact
