Here You Go...Note It Down For Future Use Also
-Engine Oil 2.7L 2TR-FE = 0W-20 ILSAC GF-5 5.1L Appx /5.8L With Filter
Brake Fluid (DOT 3 Type)
Automatic transmission oil 4 Speed ECT =(Toyota Genuine ATF Type T-IV) 10.2L Appx
Transfer oil 4WD = ( Toyota Genuine Diff Gear Oil 75w-85 GL-5) 1.5L APxx
Differential oil = (Toyota Genuine Diff Gear Oil 75w-85 GL-5) 3L Appx
Coolant = 8.6L Toyota Super Long Life Coolant In (50/50) Ratio
Power Steering = ATF Dexron II Or III
Propeller Shaft Spider = Lithium Base Grease NLGI No 2
You Can Double CHeck Details Before Buying From Toyota Dealership
