Thank you Brothers For your kind Considerations.
My pluck looked like pic-4 from the left in the Top Row. wet and Black.
Yesterday, i went to a Mechanic and Told him the story and he checked the pluck and said."Yes,You are right,Bike is Taking a lot of Fuel (Daba k Petrol pi rahi hai :).... and also Told him that bike Vibrates a lot while Driving and ask for 5th Gear
Huhhhh!!
He then Tune my bike and did the following things.
- Add some leather type Ring in Air Pipe to reduce the amount of Air. ( He told me that it is the manufacturing Fault in Hi-Speed, Engine is of 78cm3 and They use pipe of Hero Bike which Passes Air around 90-92 that is why when you try to reduce petrol, Amount of Air increases and bike Starts Knocking. Similarly, when in case of Knocking,Increase in petro results in over consumption.
I could 't Get him Exactly. May be it was due to mixture of Air and Petrol that was Causing Problem.
- He changed 14 Teeth Garari with 15 of chain.
Due to which i have felt the Following Changes...
- No vibration in Bike...Amazing!!
- Bike is Running very Smoothly not asking for extra Gear.
Your Further Suggestion is Needed.
Once Again Thank you All....
