with T/S valve removed and direct fans this is 'NORMAL'
but highly abnormal and hurting the engine. re-do the cooling system, get T/S valve in the system drain tap water and use coolant. Rig the fans to work on automatic. there will be significant difference in vehicle performance and fuel economy.
