I had the face issue.
Turns out these were two seperate issues.
Ac turning off on idle or low speed:
Start the car when cold and turn on the ac and check if the ac fan turns on. If it doesn't than you need to get the ac fan motor replaced (denso is 3500 rs) and you issue will be solved as currently your ac only turns on when the pressure of the wind helps the weak motor to turn on the fan.
Low acceleration:
Give it for tuning (not just computerized) and get the tappet adjusted etc.
My problem got solved. Unless your problem different which seem unlikely, this is the solution.
Hope this helps.
