@Jah,
Heed to the above members advise, nothing else is required. Go to any Toyota dealership and tell them to carryout a 'SERVICE' on injectors and fuel pump, thats it. It may cost you a bit more then a roadside mechanic (diesel lab) but in the long run its worth it.
Assuming that you have only done the oil change uptill now, you must on every 3rd or 4th oil change, change the fuel (diesel) filter and air filter preferably on 2nd oil change.
And after every 6th or 7th oil change, change to some other brand like Petromin, ZIC or Fuchs and then revert to your original oil brand, your engine will like it. Its like you eat KARAHI every day for a week and then suddenly DAAL comes on the menu, you will like it more, dont you? Everybody needs a change, isn't it?
If you want to do a DIY, then get a good Carb cleaner for diesel engines, (I used NASA CARB CLEANERS) open the air filter box, spray it in and then start engine and rev it up (repeat this three four times) and then open up fuel return line (just a bolt on the engine nearer to you) and ensure that orifice is clear OR if you like to use fuel tank versions of cleaners then pour in with full fuel tank and go out for a very very long drive and fill the tank again when its half full, that will keep the carb cleaner going for longer time.
One of our fellow member advise liqui Moly, which seems like a good cleaner and details are here........
https://www.pakwheels.com/forums/engine-transmission-powertrain/71709-d4d-diesel-engine-5
And btw, keep your injectors and fuel pump serviced every 25K KM in Pakistan.
Cheers,
Kaleem
