for getting 5kw peak power you would be best installing atleast 6500W panels.. and that peak will be only for 4 5 hours max in spring and summer time when sun angles in light at max absorption level.
first you need to define what you plan top run on it, n daytime and night time. as just installing the panels themselves isnt the science alone. inverters, frames, wiring and batteries all need to be configured accordingly.
and most important, what is your max buget and what are your expectations from your system?
you can PM me instead directly to avoid mixing of information.
