Ne body have ne idea where to find number no of premio on its engine i cant seem to find it newhere! on blk if ne one can pin point me the location!
regards
bump
c'mon guys itz kinda urgent!
@ TuNpArTy
would have been more then happy to help u out but hav no idea bout iti dont think any of the Karachi members hav a premio
you shuld either post this on @ Marks or ALtas thread they may be able to help you out
thanx! which section would i find Marks?
Marks threadhttps://www.pakwheels.com/forumreply_az_TopicID!43049~ForumID!20~pw.html
thanx buddy found em:)
ne one here got a premio n will to help me out findin the engine serial number
plz feel Free to Drop in a line:)
mil gaya Number i'll post the pix of itz location
so that others can benifit from it
guys found out where to find Engine serial number for Premio 2005
attaching pic
Good Work, will definately benefit some of us here
Salam bros... the spot shown in the picture is not the right place of engine no on premio.because on this spot you will find a vertical stiker like plate which cannot be engine no. and it is 5 digit. Engine no's are not 5 digit and not written on removable plates. engine no's are 7 digit and must be punched or stamped.the right place to fine engine no on Toyota premio is pop up the hood....look in to the gap between inlet pipes...the black color 4 pipes having 1nz tag on them. between the Gap of pipes start looking from your left side while you are bowed in front of car.you will find it in 1st or 2nd gap, a mobile light or torch lite will be very helpful. you ill see a punched number starting from an alphabet may b c or f or what ever the series is and you ill find 6 digits.and remember look deep on the block. don't try to look below black plastic tappet cover. hope this ill b helpful thanks
