FXR150
Capacity 147 cm³
Cylinders 1
Engine combo air/oil cooled DOHC 4 stroke
Power almost 20 PS (15 kW)
Weight 118 kg dry
Drive chain
Fuel Economy 60mpg
Specifications
Dimensions and dry mass
Overall length 1985 mm (78.1 in)
Overall width 665 mm (26.2 in)
Overall height 1095 mm (43.1 in)
Wheelbase 1325 mm (52.2 in)
Ground clearance 160 mm (6.3 in)
Dry mass 118kg (260 lbs)
Engine
Type Four-stroke, oil cooled, DOHC, TSCC
Number of cylinder 1
Bore 62.0 mm (2.441 in)
Stroke 48.8 mm (1.921 in)
Displacement 147 cm³ (8.99 cu. in)
Corrected compression ratio 10.7:1
Carburetor MIKUNI BS29
Air cleaner Polyurethane foam element
Starter system Electric and Kick
Lubrication system Wet sump
Transmission
Clutch Wet multi-plate type
Transmission 6-speed constant mesh
Gearshift pattern 1 down 5 up
Primary reduction ratio 3.500 (70/20)
Final reduction ratio 3.428 (48/14)
Gear ratios, Low 3.000 (33/11)
2nd 1.857 (26/14)
3rd 1.368 (26/19)
4th 1.095 (23/21)
5th 0.923 (24/26)
Top 0.800 (20/25)
Drive chain RK428HO, 132 links
Chassis
Front suspension Telescopic, coil spring, oil damped
Rear suspension Swinging arm, coil spring, oil damped, spring pre-loaded 4-way adjustable
Steering angle 35º (right and left)
Caster 24º
Trail 85 mm (3.35 in)
Turning radius 2.6m (8.5 ft)
Front brake Disk brake
Rear brake Disk brake
Front tire size 80/90 17 44S, tube
Rear tire size 100/90-17 55S, tube
Electrical
Ignition type Electronic ignition (CDI)
Ignition timing 9º B.T.D.C. at 1500 r/min
Spark plug NGK CR8E or DENSO U24ESR-N
Battery 12V 14.4 kC (4Ah)/10 HR
Generator Flywheel magneto
Fuse 20A
Headlight 12V 25/25W x 2
Turn signal light 12V 10W
Brake light/taillight 12V 18/5W
Speedometer light 12V 1.7W x 2
Turn signal indicator light 12V 1.7W x 2
Neutral indicator light 12V 1.7W
High beam indicator light 12V 1.7W
Capacities
Fuel tank including reserve 15.0 L (4.0/3.2 US/lmp gal)
reserve 3.4 L (0.9/0.8 US/lmp gal)
Engine oil, without filter change 1000 ml (1.1/0.9 US/lmp qt)
with filter change 1100ml (1.2/1.0 US/lmp qt)
with overhaul 1300 ml (1.4/1.2 US/lmp qt)
