Just because it has a cool name "HIGH OCTANE" and it cost more, does not make it a "BETTER" fuel lol. If you have a regular car, (ie every single locally made car in this country) then you totally dont need to use high octane. In that case it wont "hurt" your engine but you wont get ANY BENEFIT from it, its just your imagination if you think you are or others say they are.. Take someone's car yourself and go fill it with regular and tell them you put high octane in and see their reaction to "how better it was"
Oil companies make most of their profits off of high octane fuel, its actually regular petrol but it takes more to ignite it. It should only be used in engines with a higher compression ratio, ie if the car says specifically "use high octane / premium fuel only" then those cars its better to use it... but those cars are newer cars and have newer computers and sensors so even if you take a brand new S-Class mercedes or Petrol landcruiser and use regular fuel in it, your unlikely to see knocking, but a slight decrease in performance and milage.
So basically put, there is no reason whatsoever to use high octane in a COROLLA GLI lol seriously, dont waste your money or time.. and yes you can mix it why not its still petrol in the end!!
