150W HID's will produce enough heat to melt your Headlights. If your Prius has Projector headlights, the HID's will burn the chrome causing the light to fade overtime. This is permanent damage and the only solution to this is to swap out the Projectors or change the whole Headlights.
Also, if your HID is Chinese (even if it's not), there is no way that it's 150W.
