I bought toyota gli 2016 manual transmission but when i apply accelerator it makes sound higher than usual . It makes sounds like Rpm is higher but it is normal
Can you make a video of the engine bay while pressing the accelerator? And also show the rpm meter on idle.
if it is a "gooon" sound when the wheel rolls, the wheel bearings are going bad.if the rpm goes high, but the car isn't going that fast, the clutch plates are going bad.
other than that.. you'll have to elaborate more.
