Hi
I am fed of of the bumps of my Hilux, specially after using it with my Prado. The difference in drive just makes it a hundred times worse.
Unfortunately due to different work purposes I need to keep both.
Im looking for ways to soften the vigos ride, at-least as much as possible.
I’ve considered the following options please advise:
1) putting 2 sand bags in the back, however I’m a bit reluctant as they will eventually leak and create a mess. (Quality of boris in pak isn’t very good)
2) filling up the cargo box with sand. (Sand won’t go anywhere as it’s sealed, but it’s not exactly right at the back so I don’t know if it will have any effect, and if it will be able to hold that much amount of sand)
3) putting blocks of cement at the back. (They might jump and break the plastic on the trunk bed and be noisy)
Please advise if any of these solutions would be useful, and or if not any other way to make the Hilux soft.
Thank you
