If you are living in Lahore. You are lucky otherwise i can educate u enough to know whats going on.
That inverter is overcharging the batteries thats why water drying up.
Local ups is best option. Problem is local ups makers dont make good products or are less experienced. Leading to so so result.
Some inverters companies in new models have already cancelled the option of cut of charging means inverter is always charging.
Man. You are using the best battery one can buy. If it dies n dries quickly. Please change the damn inverter.
The reason why i said u r lucky if in lahore.
I have a friend Abid. He makes Local ups with quality as equal to " jitnay pesay utna material" instead of asking for 1000 watt ups and local maker makes it of 400-600 watts saving money by cheating.
Call him and buy from him. 03034485038. I guarantee you, you will thank me later.
He makes new ups in 2 days and tests vigorously by checking every damn fault it can make. Even if u call him at 2 am. He will come and fix the problem until ups is as new. And he uses good materials means safe ups. Safe battery charging. No need to buy fast chargers. His ups has so many options that if i put the list of his ups and local ups or inverters side to side. His ups will win by 15 + options more than both.
He uses good quality solder. Good amount of solder
Good fat wires instead of thin ones in local cheaters.
He for example uses breaker of rs 600 While cheater use 150 rs breaker.
Uses copper wires and copper wires transformer and varnishing it with petrol to make its life longer lasting.
So many things.
If u still think i am trying to just sell u a cheap advertisement. Then ask any ups make how fat are the wires inside inverter or local ones. They will tell u 2 mm diameter. Yet he uses fat ones like 6 mm.
He also makes almost any electronic.
He makes stabilizers with same quality and experience.
He has experience if 20+ years
If you are not in lahore. Thats all i can educate u about it. Good luck.
I live near multan 400+ km away from lahore but i have bought his ups and gotten two of my relatives his ups. Bith are happy. He recommends AGS battery. And recommends AGS water. No distilled water from AC because it is gull of copper impurities. So be careful.
Always ask the mechanic how much is their experience and then listen or pay them for your product.
Sent from my iPhone using Tapatalk
