Had compressor at home so thought to make this
looking nice and working !complete detail please ?
i am also have a danfoss compressor at home.but i use when gas pressure is low
How Much PSI You Put On These??
Don't Depend Much On These Cylinders ....! These Compressors are Good To Make Vacuum Pump Though....For Air Compressor.....They Will Take Much More Time
Whar about lubrication for compressor?
well i just need 30 psi for paint job and i get this amount of pressure within 2 minutes
there is 2 more pipes 1 for suction and one for lubricating
30psi For HVLP Gun But It Need Volume Too...So You Might Be Running Out Of It Too Early..Need Patience Much Of It To Complete Paint Job...And Thats Also For Small Items....!
Chinese compressors were for 11_15k at a hardware shop
Yes but they are noisy too I bought 1 but sold it
kabli compressors are easily available.i got my danfoss for 1.2k and still rocking
are they ready to use with a spray gun?
Yes but it need bigger compressor cylinder get empty so bigger compressor may solve this issue
I built one last year with a 1.5 ton AC compressor but the result (sprayed paint) was not satisfactory. Then replaced the compressor with a 2 ton. You need at least 100 psi (volume pressure) for better result. 150 - 200 psi gives smooth finish....less paint with higher air ratio.
can you share the pic n how it work? here very low gas presser we are using lpg at home from last one month
there are two suctions in the compressor.just block one.connect the other suction to any gas outlet.connect your stove with the compressor outlet.switch on the compressor and bingo...p.s=you have to open the stove at full blast. i.e you cant adjust the pressure
