You are awesome my friend!!!!!!!!...... Even just trying all this needs much more than a plain applause but you actually did it............... I would love to see you excelling in this field but with a Pakistani identity
Good Job....!! Keep Working On It And You Can Make It More Better Time By Time And Can Make Some Aftermarket ECU's
speaking of spark advance in controlled systems - I bet you were quite amused too when you had to calculate delayed spark aka retard spread on a greater magnitude to be read as spark advance for the next firing event.
Are you taking any feedback from the coils to confirm a "power cycle event". Is your injection system a batch fire or individually triggered? For kicks and giggles study the toyota xA-FE engine ECU, it sees the engine as a 2 cyl engine yet the ignition feedbacks 4 events per 4 crank poles and 1 TDC pole (only 1.6 and 1.8l) across the magnet pickups. the 5AFE does not even have a tdc sensor
truly great!!keep up the good work..BOL
MASHALLAH Great JOb done. I m happy that u made ECU for a K6A engine, the one used in my car, Suzuki Kei
Sir kindly check ur email
MashALLAH , Awsum word... have no words to say..
can u pls help me regarding the literature or theory and calculations of injection timing using MAP,MAT,TPS,CPS as im also working for an small GY6 Engine.
thx
u can find the same Engine in lots of Japanese species like:Suzuki Wagon R, Suzuki Every, Suzuki Jimny, Suzuki MR Wagon, Nissan Moco, Suzuki Carry, Suzuki Alto, Suzuki Cervo, Suzuki Cappuccino, Suzuki Kei, etc
Great work.
Sir i have a list of Questions please check your inbox
hey guys
I did some more fine Tuning + i applied HOSM (Super Twisting) on Idling Speed Control Regulation, Idling Speed remains Constant (850RPM) under Load/unload Conditions (Radiator Fan, + other Electrical Load on it). Now she runs pretty smoother and more quiet. i love when i open the Throttle & she makes an aggressive Roaring Sound. Yeah Babe.
//youtu.be/ http://www.youtube.com/watch?v=GCN2ynfbakI
Engine Control Unit using PIC Microntroller - YouTube
Best Regards Asad
so can u repair FF ECU in case they burnt
u mean Flash Failure ECU?? yes i do repair burnt ECUs, i also Refresh Air Bag Control Modules, Locked ECUs (equipped with immobilizer) etc, i also repair/design Motor Drives (3-phase, Brusless, Servo, Stepper etc) , Sine Wave Inverters, Aircondition Control Circuits + any Electronis machine etc
Dear Hameed,Can you design Cruise control for diesel engine also?
Making a Cruise Control is not a BIG Deal, dude Cruise Control has nothing to do with Diesel/Petrol, it just plays with the Engine Throttle depending on the vehcile Speed & User set Speed.
Best RegardsEngr Asad
asad bhaino actually i meant because 2 ecu of my 2 cars have burnt one during servicing station long time, 2nd my car was stuck in rain water & ecy blewboth time i took to 3s dealer & they install new one by saying ecu dont repair
if the water enters in the ECU Module/case then i am sorry to say dude its not repairable other than that mostly burnt ECUs r repairable
Asad Sb,
Have you worked on OBDII scanners with display.
//youtu.be/ OBD2 Diagnostic Tool Project using ATMEGA32 - YouTube
Is the OBD scanner compatible with Baleno 1.3 (1999). It has the 16 pin OBD connector installed. The problem is that the cable is not available for testing it with a Baleno.
Elm327 bluetooth Android Torque installation with Fiat 500 ABARTH Teil.mp4 - YouTube
