Salaam Guys
Look guys my task for this project is that i have to make a motorized bicycle which is powered by a petrol engine and i want to make the project as simple as possible
you guys can see that i dont have much space to put an extra spocket in between the engine and rear wheel spocket which is necessary to increase the torque and decrease the RPM and if i will do that by any means i do also have to put a centrifugal clutch in between the engine and the transmission system
The cycle available for this project allows me to keep my design as simple as possible and i know that there are some defects in this project which i am going to correct in my next project in which i will use a chain drive system and i do also use a centrifugal clutch
As far as the balance is concerned i am also going to put an electric starter and a lead acid battery on the opposite side of the engine so that its weight will be balanced
i am also going to upload a video of in which my bigger brother could be seen riding over that motorized bicycle
Thanks for all of you guys to share your useful suggestions for my project
