Hello everyone,Currently, my car is having this code B00C0-87. This code driving me crazy. What I have done so far:swapped the weight sensorsent the SRS-Unit to get it resetCheck all the continuity using multi meter in the harness.Thank you for reading https://www.bigbootyporn.tv/categories/huge/
srs code B00C0-87 no signal from the front passenger weight sensor
you might have to replace the whole seat if the code still remains after you have swapped the weight sensor.
I have swapped the weight sensor and the remains the same. Swapped the SRS Unit still the same errors. Check the Continuity and still the same result.
pleasure would be mine
