B16
Found in:
1990-1991 JDM Honda Integra XSi/RSi
1992-1993 Acura Integra XSi/Rsi'
B16A
VTEC
Found in:
1989-1991 Honda Integra RSi/XSi (DA)
1989-1992 JDM Honda Civic SiR
Displacement: 1595 cm3
Compression: 10.2:1
Power: 158 hp @ 7600 rpm & 112 ft·lbf @ 7000 rpm
Transmission: S1/J1/Y1
1989-1991 Honda Civic SiR
Compression: 10.2:1
Power: 160 hp (119 kW) @ 7600 rpm & 111 ft·lbf (150 N·m) @ 7000 rpm
Transmission: S4C
1992-1995 JDM Honda Civic Si-R II
Compression: 10.4:1
Power: 168 hp @ 7800 rpm & 116 ft·lbf @ 7300 rpm
Transmission: S4C
1992-1995 EDM Honda Civic VTi
Power: 158 hp @ 7800 rpm & 116 ft·lbf @ 7300 rpm
1989-1991 Honda CRX Si-R
1989-1991 Honda Civic Si-R I
1989-1992 Honda Concerto
1989-1995 Rover 200
1992-1996 JDM Honda CRX del Sol SiR
Compression: 10.2:1 / 10.4:1
Power: 158 hp - 170 hp & 111 ft·lbf - 116ft·lbf
B16A1
Found in:
1989-1991 EDM Honda CRX 1.6i/VTi (EE8/ED)
Compression: 10.2:1
Power: 150 hp (111 kW) @ 7600 rpm & 106.2 ft·lbf (144 N·m) @ 7000 rpm
1990-1991 Honda Civic SiR (EF)
1990-1991 Honda CRX SiR (EF)
Compression: 10.4:1
Power: 160 hp (118 kW) @ 7600 rpm & 111 ft·lbf (152 N·m) @ 7000 rpm
B16A2
VTEC
Found in:
1992-1995 JDM Honda Civic (EG)
Power: 168 hp @ 7600 rpm & 116 ft·lbf (152 N·m) @ 7000 rpm
1996-2000 Honda Civic VTiR (EK)
Compression: 10.4:1
Power: 168 hp @ 7800 rpm & 113 ft·lbf @ 7300 rpm
1999-2000 Honda Civic Si (EJ)
Compression: 10.2:1
Power: 160 hp (118 kW) @ 7600 rpm & 111 ft·lbf (151 N·m) @ 7000 rpm
Transmission: Y21 S4C
1996-1997 Honda Del Sol VTEC (EG)
Compression: 10.4:1
Power: 170 hp (125 kW) @ 7800 rpm & 111 ft·lbf (152 N·m) @ 7000 rpm
Transmission: Y21
B16A3
VTEC
Found in:
1994-1995 Honda Del Sol VTEC (EG)
Compression: 10.4:1
Transmission: Y21
B16B
VTEC
Found in:
1997-2000 Civic Type-R
Compression: 10.8:1
Power: 184 hp (137 kW) @ 8200 rpm & 118 ft·lbf (160 N·m) @ 7500 rpm
Transmission: S4C
B17
B17A1
VTEC
Found in:
1992-1993 Integra GS-R (DA)
Displacement: 1678 cm3
Compression: 10.0:1
Power: 160 hp (119 kW) @ 7600 rpm & 117 ft·lbf (159 N·m) @ 7000 rpm
Transmission: YS1
B18
B18A
Non-VTEC
Found in:
1986-1989 Accord Aerodeck LXR-S/LX-S (Japan)
1986-1989 Accord EXL-S/EX-S (Japan)
1986-1989 Vigor MXL-S (Japan)
Displacement: 1834 cm3
Compression: 9.4:1
Dual Keihin Carbs
Power: 130 hp (97 kW) @ 6000 rpm & 120 ft·lbf (164 N·m) @ 4000 rpm
Transmission: A2N5, E2N5
This engine is not 100% related to the other B series engines. It is a destroked Honda B20A engine.
B18A1
Non-VTEC
Found in:
1990-1993 Integra RS/LS/GS (DA)
Compression: 9.2:1
Power:
1990-1991: 130 hp (97 kW) @ 6000 rpm & 121 ft·lbf (164 N·m) @ 5000 rpm
1992-1993: 140 hp (104 kW) @ 6300 rpm & 121 ft·lbf (164 N·m) @ 5200 rpm
Transmission: YS1
B18B1
Found in:
1994-1995 Acura Integra "RS/LS" (DC)
Displacement: 1834cc
Compression: 9.2:1
Power:
140h hp (104 kW) @ 6300 rpm & 121 ft.lbf @ 5200 rpm
Transmission: S80
B18C1
VTEC
Found in:
1994-2001 Integra GS-R (DC)
Compression: 10:1
Power: 170 hp (106 kW) @ 6300 rpm & 128 ft·lbf @ 5200 rpm
Transmission: S80,Y80
B18C
VTEC
Found in:
1994 Honda Integra SiR-G
1995-1997 Honda Integra SiR
Power: 180 hp (128 kW)
1997-2001 Honda Integra (Japan) Type R
Power: 195 hp @ 8100 rpm
B18C1
VTEC
Found in:
Displacement: 1797 cm3
Compression: 10.0:1
Power: 170 hp (127 kW) @ 7600 rpm & 128 ft·lbf (174 N·m) @ 6200 rpm
Transmission: Y80
B18C3
Found in:
1995-1998 Acura Integra Type R
Power: 195 hp
B18C4
VTEC
Found in:
1997-2000 UK Civic 1.8i VTi
Compression: 10.0:1
Power: 169 hp (124 kW) @ 7600 rpm & 128 ft·lbf (174 N·m) @ 6200 rpm
Transmission: S9B
B18C5
VTEC
Found in:
1997-2001 Integra Type-R
Compression: 10.6:1
Power: 195 hp (145 kW) @ 8000 rpm & 130 ft·lbf (176 N·m) @ 7500 rpm
Transmission: S80
B18C6
B18C7
VTEC
Found in:
1996- Honda Integra Type R (Australia)
Power: 210 hp (143 kW), 136lb-ft
B20
The B20A3 and B20A5 are not considered part of the B family. See Honda B20A engine.
B20B
Non-VTEC
Found in:
Honda CR-V, Honda Orthia
Power: 145hp (106kW) @6200Rpm
B20A/B21A
The B20A and B21A are not considered to be 100% part of the B family. See Honda B20A engine.
