Aoa I have Cd 100 2012 model and i am fed up 2 dfa iss ky clutch ka kaam krwa chuka hu 5000rs bi lga chuka hu lekin again iss ki kick slip krti hy aur clutch plate farigh ho jati hy then clutch ki setting bi krwa chuka hu kafi mechanics sy but still same problem occurs So any one have suggestion how to overcome this problem OR some good mechanic in RWP jo iss ko sahi trha repair kr sky
Thanks
This problem is not common in cd70.My friend cd100 has the same issue. He caters it by pressing slowly on the kick. Squeeze to kick, not like cg125.
By the way have you changed the clutch springs also or just reused the old ones?
Have you changed the springs?
No i have just changed the clutch plates pressure plates and clutch couple I dont know about the springs that has to be changedJo chezain mechainc ny btayen thi wo change ki thi bas
I think the mechanic while fitting the clutch plates and pressure plates reused the old springs i dont know clearly about it
This is due to springs, as they are not providing the required force to stick clutch plates and pressure plates together.Or you can install stiffer springs. Just the lever will become tight.
Ok bro next time when i will change clutch/pressure plates i will make sure that the springs must also be changed Thanks for your response
Your welcome.
Bhai cg 100 k liye kis company ki clutch plates use krni chahiye??
FCC ki lagao.
