Check the spark plug color .if found back deposits. You have to adjust fuel mixture to lean. If found whitish then go for rich adjustments, in ideal conditions color should be chocolate redish brown , except this make sure no air intake leaks from carb manifold and choke lever. also make sure tapit settings is accordingly
Good luck
