I am curious to know that is it possible to install Honda cd70 head and cylinder on chines cd70 with 73cm^3 cylinder?
Yes it possible
brother please guide me, i want to change it on my friends bike but not sure what other parts do i have to change or just install new cylinder without head or head+cylinder, piston, connecting rod etc.
If bike you are working on I'd 78cm^3 or 86cm^3 than you need to change connecting rod too if it 72cm^3 than only everything will be bolt BTW why are you swapping Honda parts engine dead?
i am working on road prince (73cm^3 written on cylinder), piston rings worn out. lots of noise from head and timing chain. Therefor i decide to totally change the parts with honda cd70.
bhai cd 100 tak ka head cd 70 ma install ho jata hai.if its 72 then no problem of installation of both head and cylinder have same fitting but if its 78 then just install head and piston don't change cylinder or you have to change connecting road which require a lot of work.
thanks brother, and i apologies for mistake, i wrote 73cm^3 instead of 78cm^3.
Brother cd 70 ka head cylinder kitny mein mil jata hai? Used or new please guide
New one is about 600 to 700 Don't go for old one as all of them are sleeved or needed to be sleeved which decreases life of a cylinder.And there's not much differece between the price of new one and old one.
Thanks.Aaj reply dekha but ly liya tha
New or old?
New liya bhai 1300 mein
Cam timing kaha sai set hoti hay T mark py yaa F py?
Bhai muja dokan dar na 600 to 700 kaha tha between konsa brand ka apne liya hai?
In between T and F jahan magnet ka move krna prr valves hilna band kr deta haien vahan
Getting my messages?
Asking to whom?
Crlf company ka...Aur bhai bike ka engine jor kr chalaya but valve loose hain boht aur start sahi hota hay lekin valve tight kro to start nahi hota bike (valve mean tappet) Aur f pe timing set ki thiAny idea?
tabbets ki setting hoti hai ap zeyada tight karo ga bike band hi gii kam karo ga to bike sa "tik tik awaz aye gii"dusara bhai T pe timing set hoti hai lakin zeyada tar bikes main f or T ma middle ma lakin zeyada lean T ki taraf
Thankx brother...Ab ok ho gai bike ?0?4
I know I did nothing still your welcome [emoji6]
