Assalamualaikum..my Honda 125 model is 86 which was being used by my father now I am using it.I am used to driving CD 70. I am facing these problems in this 125.1-Its speed doesn't go up than 60-70?2-In the morning when it is cooled, it accelerates very very badly. After 7 or 8 km drive it gets better why is this problem?I would be grateful if someone would give me valuable advice.
Dear ....
First check you point setting
Also check the slide notch setting of carburetor and clean carburetor if required.
Hassan sb,
why old model cam garari is so expensive.... If we use normal cam when will be effect on engine performance and what is the main purpose of a cam garari.
Which is best Brand of weight bearing of honda cg 125
