the first check-up is at 1000kms, the tuning i think is at 15,000 or 20,000kms..u can look that up in the owners manual..the same goes for the brake..just make sure they adjust it while putting it back,take a test drive and check if ure car shakes while braking at high speeds..
Oil should be changed...depending on the quality of the oil,caltex havoline is my favourite and i change it after 4000-5000kms..some people use the greenish/blue shell one..it depends on ure driving conditions too,inner city driving should need a change every 4000kms..
one thing i would like to add is make sure u have a clean air filter, which makes a huge difference in the engine's performance as well as the fuel consumption..
hope this helps
