What should I get checked on the car? It has no maintenance history.Oil needs changing for sure what should be recommended oil grade and brand? I was thinking to go with synthetic 10w40 havoline. The car was used on CNG but it was disconnected when I bought it.Should I replace the Transmission Fluid?
Replace All fluids (Transmission, Engine, Brake & Coolant) for engine oil 10w40 is good to goCheck All Belts Check Brake Pads (Front and rear)Spark Plugs and Valve clearance
