I believe I found the solution, once your battery is good, along with spark plugs simply do this. This may seem silly but it worked for me. Disconnect your car battery, go to you fuse box located under the steering wheel and use a thin flat head screw driver or pliers to remove all the relays one by one and resit them. To use the flat head screw driver, pry it at the bottom of relay and force it out. Strange enough it fix the starter problem. Be aware that the blue relay was not move. Reconnect the battery and try starting again. Honda City 2011
