This member comes up with the most off the wall concepts that you will know, in another post he came up with a statement that EFI engines do not have injectors, and started to argue that THEY DO NOT HAVE INJECTORS and fuel is mechanically adjusted, to top it all it was a technical help thread of someone elses.
Now this, What Mr Sohna is saying that engine tuning means engine configuration should be changed, WHY? when the same mechanical setup can cater to nearly every part of the world with different ECU setups, do we need to change something on it to cope with the flash.
the ECU flash can cater to all operating charecteristics of engine operating requirements, be it run with 10% alcohol mix fuel or with your regular brew 87 RON fuel you buy at the pump.
Your brain, your boat - whatever rocks it is best for you, I thought PW had a little sensible people on board - but actually saying that wrong is right, and then putting up chinese proverbs along with you learn from anything, anywhere.
Learn YES, most welcome - but something like 2 and 4 is 6 not 2 and 4 is 9 - then reasoning that if you see 9 upside down its six and hence true. I dont need to prove anything to anyone here, I did not go to Engg school to correct people's concepts on forums neither gather respect, For them the earth can be flat. I wouldnt care less.
