Respected Forum Members,
Hopefully you will be having a good time. I am posting here to get your valuable suggestions regarding AC problem of Honda City 2010.
AC of my car trips continuously with margin of 5-10 second and it did not turn on until temperature is too high inside. I went to a local AC mechanic in Lahore and he told me that coil of AC compressor need to be replaced. He replaced the oil and washed condenser. AC started working properly but after half an hour it start trips again. Then I went to another Mechanic because I was not in Lahore He told me that AC is perfect, just wash the condenser, I did the same but problem was not resolved. As I was out of station I went to another AC mechanic and told about previous history. He told me that gas level is less than half, It need to be filled but I told him during previous check up both mechanics said that gas is full. Anyhow he filed the gas. AC performance was little bit improved. After that I decided to visit Honda dealer in Lahore, They said we will check it properly but due to rush hours they provided me temporary solution by decreasing level of gas, By doing this AC stopped tripping but cooling was very less. They asked me to visit after eid holidays. After that I visited the first mechanic in Lahore who changed the coil he said that AC requires service. He washed condenser and evaporator, by which fan speed become better and AC starting working in efficient way. Its cooling was also very good. But it worked only for one day. Now I am really very exhausted by this situation.
So all of you are requested to give your valuable suggestions to resolved this problem.
Thank you
