Hello pakwheelers....i am facing a problem from last few days....my car's ignition switch is causing me headache....initially when it started as when i put my key in ignition switch,it took a bit effort to insert the key in ignition switch....as if there is some blockage ahead....but now it got worse....i had to push they key hard into switch and it gets in after 2 or 3 hard efforts....now i noticed that it also stuck up when i try to get it out from switch....i tried the spare key but it happened to that also....need suggeations wat to do......any solution as i dnt want to get loot up from local mechanics
